Question on rear brakes for an S2
My rear brakes need replacement and I just happen to have an extra set of pads from my front brakes that can be used.
My question is, are the two pad sets the same?
Also, once I'm in there is there anything special I need to remember while replacing these pads?
Thanks!
Thanks!
On stock S2 (non-M030), the brake pad size is identical. You can use the same size pads as the fronts.
If you're careful, the pad sensors can be removed with needle-nose pliers and re-used.
