intake cfm #'s
--I AM NOT TALKING ABOUT CONE FILTERS, or gaining 80hp with a bolt on, AND DO NOT WANT A DEBATE ABOUT THEM TO START, ---
This is for a complete motor build of a 2.7.
I am about to dive into my intake manifold project and looking for some flow #'s
any body have flow #'s of a stock NA manifold?
throttle body?
or an equation to determine aproximate cfm for the throttle body by diamter?
the plan is to cut and shorten runners on a stock manifold and create a larger plenum above it to optimize it for higher rpm, and blend the tops of the runners to imitate velocity stacks.
thanks!
derek
throttle body?
thanks!
derek
As for stock numbers, I'm unsure, but there are flow calculators and intake plenum design calculations online if you google search "intake manifold design" or "plenum design" and I have found that the factory runner length for an S2 is optimized at about 4400RPM.
What RPM are you trying to set the peak torque at? What are you trying to achieve by running a larger plenum?
Changing the diameter of the runners works as well as changing their length.
Does not take into consideration the resonance or pulsing of the intake. The reason for a plenum to absorb the shock wave.
awsome, thanks skunk. looks like bored or custom throttle body is not necesary
i am trying to optimize between 4-7k rpm, and have read articles all with the info that plenum volume should be about 1.5 to 2 times the engine displacement, to answer your q.
I ran the #s for the NA and turbo intakes, as far as I can tell, they are like spot on for performance. The plenum size I beleive, is supposed to be based on the volume of one cylinder's displacement, not the total. And yes, I have read the 1.5 to 2 times the displacement as well. If you want some good reading material... Forced Induction Performance Tuning by A.Grahm Bell. I was looking into design. When tuning, you can do a loop runner off the back of the plenum around to the bottom intersecting at 90 degrees, to even air flow. I'll be damned if Porsche didn't do this with the 968 intake. I can't say that they missed much of anything, I can say that they withheld some tech on the 944 series. The diameter, the length and the plenum sized all checked out when I ran the #s. If you want to move the power band up sacrificing down low, pull about 2" off the length. That would put the length at the low side of suggested and moving power to the upper part of the revs. If you don't have it, get the book, about 40 bucks and priceless on the info man. Prolly my best book find yet! Good luck
already got that under control,, milledge cam. I was actually lookin at using an elderbrock or ricer supply company throttle body somewhere in the 65-70mm range.,
nine-44 i have also heard the 2" shortening form another source, so this looks like what i might do. the turbo manifold looks easier to shorten but has a smaller plenum, so i might go this way and make sure the runners come out at 2" shorter than the NA.
Calculation based, the maximum our engines will flow is about 270 CFM at 1 BAR. Something to keep in mind.
Originally Posted by Serge944
oops, 2.5!. Just multiply 270 by (2.7/2.5)
I know from a recent conversation with Jon Milledge that the 2.7 head does not flow as well as the 2.5 head.
geo -oh really, seems odd since the intake is much larger, maybe the port is too big. does the intake or exhaust suffer on the 2.7 head? and by how much?
