Stripped camshaft retaining collor bolt(cheesehead)
I've been in the slow process of trying to track one down here, but in Ohio. I found a few sets on ebay, some specialty online tool dealers, but I haven't found them anywhere in a walk in store. Most people have no idea what I'm talking about, they give me the "torx" thing too.
Take a look, google search for SK triple square.
http://www.mytoolstore.com/sk/sk03093.html
That's just one that comes up. I'd get the set (I have it - it's great). That price isn't too bad either.
update - search for SK 19704 in google (or froogle) that lists prices starting at $35 for the set.
Oh yea, don't cheap out on these bits, you'll regret not getting good ones (like the SK)
Dal.
Resistance is Futile
Easy now folks - don't go off on a tangent here but there were two types of these bolts over the years. The original was replaced with the 12-point and while one is doing anything with regard to the CAM itself, do NOT allow the cam pulley to move more than a couple of degrees less you want to worry about valves. For Christ's sake, do it by hand and not with an impact wrench as you may shear the bastard off in the cam. Right tool for the right job is as accurate as you can get. Heck, check my avatar...
Originally Posted by Dal Heger
We were. The drill bits were that bad.
I'm happy that I inherited my father's drill bits. He was a machinist/toolmaker, he had the most awesome set of tools!
I never had a problem drilling anything out with that set of bits. There is a difference in quality!!!
Dal.
Dal.
I've purchased my set of cheesehead bolt tools from either a Napa or a Shucks auto parts store. It was not call a "triple square" set. It was labeled and called a "12 pt. serrated, internal wrench set". What it amounts to is a set of bits, that have the 12 pt. "triple square" bit on one end, and a 13mm allen on the back end. I would prefer to have the socket set in 1/2" drive for this, but, haven't gotten around to buying them yet. I haven't needed to. This set has worked just fine for me, so far. Note: You also WANT to invest in a real good, 1/2" drive, 17mm allen socket, for removing/installing the plugs on the transaxle. Those cheapie 17mm VW drain plug socket things at those stores, are a waste of money, IMHO. You'll be replacing those plugs.
When you go into stores do you ask for cheeseheads? It is a common misconception, but the technical term is triple square or 12 point internal. Cheesehead is just a common term for anything with a smooth, round circumference(i.e. hex, triple square, or torx). I got my triple square bits from Pep Boys (set of four for ~$15).
I call them triple square bits, and nobody knows what I'm talking about.
I bought 2 cheap sets of the Lisle ones at Partsource, and they're nothing short of crap. I've had them replaced more times than I can count, and once I lost the receipt, so I had to buy a second set, and now I have 2 rounded off sets...
And that's precisely why I hit up the local Snap-on guy... sure, it cost me 32 bucks but I've had nothing but precision from it.
i think i might just have to take the cam cover off to drill this bugger out.theres no room to drill with the cover on.tho,theres that 90 degree adapter,i cant seem to find it anywhere locally.is it easy to remove the cam cover?any specially tools?thanx
I've found "cobalt" drill bits to melt like butter through bolts like this. Everything else is like trying to drill with a Q-tip. Snap-on has good triple square bits. Harbor Freight has a cheaper alternative.
ive got the bit,i got em at napa for $6.it does come with a socket,but you fit it into a 13mm socket.man,i wish i knew napa had it before stripping the damn thing.everyones reccomending cobalt drill bits for the job,so cobalt it is.
I checked at my local NAPA and they'd never heard of it, I'll check autozone Andy, would you guys think that Harbor Freight or Autozone would have the better bit? Both of those are pretty close to me.
i had to pry it out with a punch and hammer. spray it with some PB blaster or something first
