Anyone have a pin-out of an early DME harness?
Set to Full-Auto
Title says it all, looking for a pin-out for trouble shooting and havn't been able to find this info in the factory manuals.
Hates Family Guy
This interweb thing has got everything on it. I found this somewhere, once. I don't remember where and no I don't have a larger version.
Hope this helps,
The wiring harness diagrams on the ‘early’ 944 engine harness has a white plastic ‘Molex’ connector (by the brake booster) with pin:
T9
1 – green (Ignition Coil)
2 – red/blue (Injectors)
3 – red/yellow (Fuel Pump Relay)
4 – black/green (Supplementary Air Valve)
5 – black/gray (Fuel Pump Relay)
6 – black/white (Oil Pressure Sending Unit to Dash Gauge)
7 – red/black (Starter)
8 – blue/yellow (Coolant Temperature Sending Unit)
9 – blue/black (Oil Pressure Sending Unit to fuse panel)
Grounds to Pulse Sensors on top rear of block
- Speed Transmitter (DG - Top)
- Reference Mark Transmitter (BG - Bottom)
Michael
T9
Michael
Sharky,
If you need any parts for the early car, let me know. Looks like I'm going to have to part the 924S "Lemans" car. Was hoping to save it, but it just has too much body damage. Took it to 2 different shops, and estimates were pretty well up there.
Set to Full-Auto
Well, I need a fuel pump for sure now - we put 12v right to the pump and it remained silent.....
What kind of performance goodies came with the Lemans?
Originally Posted by michaelathome
Hope this helps,
T9
Michael
T9
Michael
I think the pinout of this connector stayed the same from 83 and on.
