I'm finally re-installing the head and had to stop because the two allen head bolts at the front (water temp sender?) are in such bad shape as to be useless. I didnt notice it until I cleaned them up for installation. Where can I get these? I looked at pelican and paragon but no luck.
Kind of sucks, I would have finished tomorrow if it wasnt for that. sigh
oh thanks, I picked up some M8x1.5 but was worried about them being 1.0 instead. ONe is definately 35 but I could only find 30 and 40 and 50. Hopefully those lengths will work
I hate those bolts.. if you can give the measurements of which works.. let me know as I need to get them as well. i broke my block trying to get those damn things out.
fyi - the short one is a bit more difficult to tighten down as a hex head. You cant get a socket in there.
I got mine in...
If you look really hard, its possible to find M8 bolts with a 12mm head... Not the usual 13mm. Either way, I got one with the 13mm head on and torqued using a 12 point socket.
