FR Wilk Chip Review. Finally On Rennlist!
Sean, as far as i know FRWilk does make a chip for the '88 and even the 2.7L '89 cars.
http://frwilk.com/944dme/
Im looking foward to seeing Wilk's HFM5 conversion. Basically a replacement to the AFM on the n/a cars. Looks promising, and if its nearly as good as his chip...may just be worth the price of admission.
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Originally Posted by URIN 2ND
No one seems to do a chip for the '88 cars, I should mail him about that. I know the mapping was different, but I wouldn't think that it can't be improved on...
This is a good example that the chip definitely richens the fuel mixture to give the car a little more edge in the higher RPMs and optimizes the air/fuel ratios. If it could be improved upon anymore, I fear a large amount of black smoke and repeated backfires.
I just want some fire to come out of my exhaust, thats all i ask!
Im confident if i put my old FPR back on and took the cat off i would get that! It ran so rich my eyes would tear from the exhaust. Hell i used to tell my friends in a serious matter to not smoke next to my car.
Mexican Ambassador
straight pipe it! flames are worth any fix-it ticket! oh man. imma post a video of my 3rd-4th shift with flames pretty soon, and then it'll be my avatar or maybe in my sig..... awesome...
Fuse 24 Assassin
Fuse 24 Assassin
ok poll time then! hehehe
Who wants me to put a straight pipe on the car with the Wilk chip and keep this exhaust on:
And take a video of me pissing off all my neighbors accelerating away with a 110 dB 944?
Originally Posted by TheStig
jgleano, the FR Wilk chip has 2 programs in it; the factory and Mr. Wilk's setup. To set your car back to factory programming, simply remove the bypass plug he gives you and plug the altitude sensor back in. His program is enabled with the altitude sensor is disabled.
Have you taken it to 7000rpm yet? You can do 0 to 60 runs with out up shifting to 3rd as the rev limiter will not intrude until you reach 7000rpm.
With the gas prices as they are, I made the mistake of filling up with 87 octane as I use to do before installing the chip and the car pinged something awful in power prom mode, I switched it back to stock settings then things were back to normal until I ran the 87 octane down. It runs great with 89 octane in power prom mode (no pinging) but I guess that will depend on the condition of your motor.
Best bang for the buck that I have found for an NA so far.
Mexican Ambassador
you've got my vote for the cat bypass, just save ur old cat. are those KYB's in the rear? what's up with that, son? oh, and i like that....exhaust pipe..thing...that's sticking out. maybe i'm ignorant, but wtf is that?
Fuse 24 Assassin
Fuse 24 Assassin
KYBs yup. All the way around. Do I autocross with them? yes. Do I like them? yes. Are they stiffer than NEW BOGE shocks? YES. I actually don't mind them. When I update to 968 rear M030 shocks with the helper springs I'm going to go Koni in the front though with the ride height kit from Paragon. For now, that is the most inexpensive shock to improve the handling on my car that is compatible with my M030 sways and 220 lb springs
Oh the rear pipe is a megaphone. Old 911s used to have megaphones that were raced to give the maximum flow of exhaust. They attached to the headers. I decided to go with a megaphone for a racing exhaust because of the vintage look of the tip and that it was a homologated racing exhaust for vintage Porsches....it's not for the 944 though; but I like to be unique and lighter
Stig, i hear you said it runs rich.. maybe something's not quite right? I've heard that poeple generally get BETTER gas mileage with teh chip. at least that's what i've read from users on pelican.
