Rear Cam Cover
it was made that way, it's actually a 928 part and the 4th hole is so it can be mounted on either head of the 928 motor. Normal and nothing goes there. HTH
right, the gasket is to be flipped according to the side it will be used on, the part is universal per side (just use the proper hole)and the bracket I beleive is a 944 part. The gasket will cover the hole in the cover and there is no 4th hole in the cam box.
These 3 little bolts like to back out over time for some bloody reason. I just got into the habit of giving them a little twist of the wrench about 3 times a year on a daily driven and heavily tracked NA.
