View Poll Results: What kind of fuel for your baby?
Regular unleaded (87)
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
23
21.30%
Mid-grade unleaded (89)
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
9
8.33%
High-grade (premium) unleaded (91, 92, or 93 - whatever your area has)
![](https://rennlist.com/forums/images/polls/bar4-l.gif)
![](https://rennlist.com/forums/images/polls/bar4.gif)
![](https://rennlist.com/forums/images/polls/bar4-r.gif)
71
65.74%
50/50 unleaded & race gas
![](https://rennlist.com/forums/images/polls/bar5-l.gif)
![](https://rennlist.com/forums/images/polls/bar5.gif)
![](https://rennlist.com/forums/images/polls/bar5-r.gif)
0
0%
Pure race gas baby! It ain't that much more expensive than pump gas anyway!
![](https://rennlist.com/forums/images/polls/bar6-l.gif)
![](https://rennlist.com/forums/images/polls/bar6.gif)
![](https://rennlist.com/forums/images/polls/bar6-r.gif)
4
3.70%
Methanol! I NEED to run 50 psi of boost!!!
![](https://rennlist.com/forums/images/polls/bar1-l.gif)
![](https://rennlist.com/forums/images/polls/bar1.gif)
![](https://rennlist.com/forums/images/polls/bar1-r.gif)
0
0%
Other (explain)
1
0.93%
Voters: 108. You may not vote on this poll
What kind of fuel do you guys run?
#46
Campeck Rulez
Originally Posted by Zero10
I run 87 octane in the 951. Never had any knock or detonation problems in it, even at about 13psi of boost (then again, when it ran badly, I didn't get knock at 23psi with 87 octane either...).
thats because the knock sensors are pulling out timing like crazy.
do i have to say its moronic to run 23 psi on 87 octane... and dont you have the stock k26 turbo? can you say....no effieciency whatsoever. havent you already gotten yelled at on the turbo board for that...
#47
Campeck Rulez
Originally Posted by eohrnberger
You suppose that a 10.9:1 NA engine would like that mix as well? You know, perform better? Can't see why not. The DME would advance the spark and enrich the AF mixture so match, wouldn't it?
the dme has no qway of knowing what fuel you put in it. (unless its bad fuel and causes knock)
it only knows knock. when it senses it..it retards timing. if it doesnt..it doesnt.
if you put uber good fuel in the car. ther computer doesnt know that it can make more power from it. im not sure if the S2's have a fuel quality switch like the NA's
if it did you could advance the timing maybe? otherwise your just wasting your money.
#48
I used to put only premium in but now with th rcent gas prices i ahve been varying myeslf. if i am emppty sometimes i will go with 89. Though sometimes i do still put in premium.
