944 Transmission Mount Replacement
Old 04-21-2009, 12:54 PM
JohnKoaWood
JohnKoaWood's Avatar
Originally Posted by Sysgen
I just did the same thing last week.
Very easy to do, the tranny rests on the torque tube when completely dropped. Then the crossmember comes out of the left wheelwell, I also had to remove my shock bolt.
Should be the same procedure for the supermounts.
Alan, can you give more example of your clutch judder? and Moook, I have a Spec I clutch also and I get enormous judder but only when the car gets hot after a long ride.
Do you both have this symptom?
When you did your clutch did you resurface the flywheel, I am thinking your judder when hot is distortion of your flywheel OR pressure plate... Just 2C worth..
Old 04-21-2009, 12:56 PM
Sysgen
Sysgen's Avatar
Clutch was done by a very reputable porsche shop and the flywheel was resurfaced, but let's say it was not done correctly, why would it only do it when hot? Metal expansion?
Old 04-21-2009, 12:59 PM
The DareDevil
The DareDevil's Avatar
Did you take it apart to inspect it? I remember you said you would do that in the spring.
Old 04-21-2009, 01:03 PM
Sysgen
Sysgen's Avatar
Arghhh, did I say that? I don't remember saying that, must be old age
I do not plan to take it apart myslef, too much of a pain.
Old 04-21-2009, 01:04 PM
The DareDevil
My mistake... You said the very reputable Porsche shop would do it.
Is it getting better?
Old 04-21-2009, 01:11 PM
Sysgen
Sysgen's Avatar
I've only driven it 2 days since it's out of storage but it wasn't better.
Old 04-21-2009, 05:06 PM
Sysgen
Sysgen's Avatar
Bumping this so that Alan and Moook can see it
Quick Reply: 944 Transmission Mount Replacement
