throttle return spring
Well, got the 'S' back together after intake work (ISV, TPS, vac lines, throttle rebuild, injecters professional cleaned...). Runs very strong, but the throttle spring no longer wants to pull the throttle all the way to the idle contact switch unless I let up very quickly. It only misses by a hair. Car's almost undrivable this way (stalls alot). What do we do about this? Stronger spring?
______________
white '88 944S
______________
white '88 944S
They wear with age too. Had a friend have the spring just break at the track, stuck at WOT, had to shut it down before it blew up or put him into the trees. He now runs with TWO springs in that position.
New Porsche throttle spring (different design, same length) - same result. No surprise I guess. Cut a few coils off the original spring, same thing.
With no spring, I do feel a tiny bit of rubbing just as the throttle closes. I am guessing that's the plate rubbing the bore of the throttle body and holding the throttle open. After I cleaned and rebuilt the throttle, the fit was near perfect - no visible gaps. I don't remember the rubbing, just how smooth everything worked. But who knew a little rubbing here would hose me so badly.
To really inspect / correct the throttle on an 'S' is a ton of work (take the intake manifold off again).
Do I have any choices?
Alright, I gave in and pulled the intake manifold off again (it's amazing how quickly things go the second time in two weeks, heh?). I was able to loosen the throttle plate screws and move the plate a touch for zero rubbing (the amount of rubbing to begin with was ridiculously small - similar to the load the TPS switch puts on it). So now the throttle closes properly and the car's idling better than ever (probably the ISV. Or the clean injectors. Or the new vaccum lines...).
