testing exhaust headers
Old 09-12-2005, 12:11 AM
Mark-87-951
Mark-87-951's Avatar
Default testing exhaust headers
While I have my cylinder head being worked on, I wanted to test my exhaust headers before sending them out for thermal coating. Is there an easy way to do this?
Old 09-12-2005, 12:21 AM
MPD47
The Carnage King
MPD47's Avatar
Test them for leaks? I seem to recall a method of forcing compressed air into them while submerging them and seeing if any bubbles come out of random spots. Sorry I cant be of more help.
Old 09-12-2005, 01:34 AM
kennycoulter
kennycoulter's Avatar
sticking potatoes in the ends while its under water?
Old 09-12-2005, 08:00 AM
Geo
Geo's Avatar
Test them for what?
Where are you sending them for coating? The best coater in the country is in MPD47's neck of the woods - Swain Technology. Their termal barrier coating (White Lightning) is way better than anything else out there.
http://www.swaintech.com/race.html
Old 09-12-2005, 08:21 AM
special tool
special tool's Avatar
This is what you do with stock headers - no arguing wth my datalogger, please....
-remove headers and crossover
-remove factory heat shields with 4" angle grinder with cutoff wheel
-bring pipes to tub and fill with water, stopping end with one of those
rubber things that your wife opens jars with
-check for water leaks
-weld leaks
-wrap pipes with DEI or thermotec (Summit Racing)
-spray wrap with special coating
You will gain 100-150 rpm spoolup.The bad thing about the factory shields is that they HIDE leaks - though they were good for the first 15 years.
The wrap is MORE effective at energy retention than the factory heat-shields.
I am not speculating here, guys.
Old 09-12-2005, 09:01 AM
Mark-87-951
special tool
Unfortunately, I don't have a compressed air source right now. would thermal coating whether it be swain or jethot or some other brand be better than wrap?
Old 09-12-2005, 11:37 AM
Geo
Geo's Avatar
The Swain coating will be better than wrap. I'd guess the wrap would be better than Jethot which is effectively just a ceramic paint.
Old 09-12-2005, 11:58 AM
special tool
Nothng is better than wrap. I have datalogs
You may get slightly more energy retention using a coating IN ADDTON TO, but it does not outperform the wrap.
Mark - why do you need a compressor to use my procedure?
Old 09-12-2005, 12:16 PM
AznDrgn
AznDrgn's Avatar
From what I've seen the wrap will shorten the lifespan of the header vs the coating.
Old 09-12-2005, 12:32 PM
special tool
That is true.
Old 09-12-2005, 01:07 PM
unreal_news
unreal_news's Avatar
Would one of these methods allow one to remove the stock silver heat sheild around the inside of the engine bay?
anyone have 'white lightning' applied to their headers?
what was the cost?
found it, 125-165
wouldnt it cost an arm and a leg to ship the headers tho?
thx,
-john
Old 09-12-2005, 01:25 PM
Geo
Geo's Avatar
Do you have datalogs with Swain's White Lightning specifically vs. only wrapped? If not, your data isn't valid.
I have a header for another car with Swain's White Lightning, but don't have dyno charts to go with it.
However, I also used White Lightning on the manifol, turbine housing, and J-pipe on my turbo G20. I can tell you from direct experience that with the turbo engine run hard, the under-hood temps were significantly cooler than what they were when the car was NA with a Jethot coated header.
I did a magazine article on the swap to the turbo engine and while collecting research for the article, I talked with Swain about the effectiveness of the coating and they related the following story:
They have a underground locomotive client who needed to reduce manifold temps from 975*F to 425*F. Nobody else came close. They tried all the conventional coaters and the best any of them could do was around 725*F. When the client gave Swain a shot they hit 475*F on the very first attempt. On the second attempt they put the coating on a little thicker and nailed the 425*F target. That's less than half the heat passing through the coating..
Old 09-12-2005, 01:32 PM
special tool
The coating isn't even in the same league as the wrap - any comparison is ridiculous.
Old 09-12-2005, 01:47 PM
Geo
Geo's Avatar
Really?
Based upon what? Your opinioin? You said you had datalogs. Let's see Swain vs wrap. If you don't have them, don't state an opinion as facts backed up by datalogs.
Swain's coating is unlike any other header coating out there. It's very thick and is a true thermal barrier.
chrly924s
chrly924s's Avatar
I am thinking of wrapping mine just to reduce temps in the engine bay. Is it worth it on a 924S used for secondary driving?
Quick Reply: testing exhaust headers
