Control arm bushing install
I'm installing new "front-of-front" bushings in the control arms, does anyone have any tricks to get them entirely seated? I've used a press and pounded the living crap out of them but still need them to move 2-3 mm in order to mount into the crossmember.
are you using stock bushings? i installed weltmeister reds and i know there was a steel sleeve that had to come out in order to get the new bushings in. i'll throw up a few pics:
this first pic shows the sleeve on the other side of the arm, with the sleeve closest to the camera having been removed.
using a dremel to notch the sleeves so they will come out:
last pic shows both sleeves removed and the new bushing ready to be installed.
![](http://forums.rennlist.com/upload/weltmeister_bushings_1.jpg)
![](http://forums.rennlist.com/upload/weltmeister_bushings_3.jpg)
![](http://forums.rennlist.com/upload/weltmeister_bushings_7.jpg)
![](http://forums.rennlist.com/upload/weltmeister_bushings_9.jpg)
You're talking about the steel arms on the 924S right? Somebody over on Pelican was having trouble installing new stock bushings a week or so ago. Basically the solution was lube the crap out of them with either grease or liquid dish soap and the press away with a vice or hydraulic ram press.
