FS:87 944 NA trans
FS:87 944 NA trans
I have a vacation coming up in mid Sept and need to raise a few extra bucks.
The trans is from an 87 944 NA with 87K miles, it ran quite and shifted fine. It's a late trans with the electronic speedo but will fit early as well. $400 plus shipping. Thanks, Andy Kihm
I checked Greyhound. Max weight of 100lbs tho, it'll be close. I put in 100 lbs and 36" max length, $74.05 from Cincinnati OH to Albany NY.
I shipped one in a waay oversized plywood crate that I made sturdy enough to go to cali and back, cut up and put a full 4'x8" sheet of 2" foam board for packing and with the turbo tranny and cooler it came in at like 127lbs including fluid. That was on a trade deal I worked with Der Cupmeister.
1 Post
I will keep you in mind , as I need one. However a local member (another board) has offered his for $400 incl help installing. I am trying to scrape that together.
If his is unavailable, I may be calling you as it has been some time since the offer.
