Not a happy camper: oil smoke - now with comp #'s
Jane Bond 007
Okay - a perfect 120 psi on all 4 cylinders. The number 3 plug is a little fouled, but not bad. I'm leaning toward the HG:
All your plugs look too dirty for a gasket leak into the cylinder imo. Anyhow, you said it was oil smoke, not water smoke right? I'm sticking with a turbo seal for now. Pull an intercooler pipe and see what it looks like inside.
Campeck Rulez
yeah. all those plugs look really nasty. especially the two in the middle.
what majes a turbo seal blow? did she upgrade the turbo? did it need a restrictor in the oil feed line?
Also check the major vacume hoses that run into the intake manifold I believe there between runners 3 and 4 and 1 and 2. Mine blew out once under boost and the car was puffing out alot of black smoke. Give them a good yank and see if any of them come right on out.
Jane Bond 007
The plugs are dirty due to running rich while farting around with the ARC2. All vaccuum lines are new and secured with rad clamps. The turbo is also new. Whatever the problem is, it was an all-of-a-sudden thing. The car burned no oil yesterday and was belching it like crazy today. It is definitely oil as I can smell it and see the residue on the back of the car.
Just a car guy
Yeah - those Split Fire plugs need to go. Just get some simple copper core NGK or Bosch plugs.
Good luck - you'll have this figured out and fixed in no time.
Sounds like turbo to me. Do you have a multi piece cross over pipe? If so pull it, fire it up, and if it still fogs out of the headers. If it doesn't you know the problem lies down stream, which would point to the turbo.
Jane Bond 007
About a thou (the Fest was 800 or so round trip).
Well, the turbo looks dry, but there appears to be oil in the intercooler pipe and inside the TB:
