Need 968 parts or motor
Well i got my leakdown test back and it looks like the motor will have to be pulled apart again . The thing that makes me so angry is that i paid a porsche shop 2800 to do my rings, head, oil pan gasket, etc... to do all of this work and look what is wrong. I have no idea if they installed the rings wrong or now but i decided since i will have the motor out of the car i am going to build up the motor. Thanks in advance.
Originally Posted by marky522
You have the absolute worst luck, sorry to hear.
Mark
Mark
If you want to go 2.5 or 2.8 I have a 951 short block I plan to sell. I have not disassembled the motor and checked it out to see what the bores look like so I do not know the asking price yet. I plan to use the head and other parts but I have no use for the short block. It was a factory new replacement block and has 20K or so on it, but you never know what the bores look like until you see them.
-Joel.
-Joel.
Originally Posted by yieldsign2
You can't take it up with the shop taht did the work?
-Joel.
-Joel.
So what are the 968 pistons for? If you sleeve for 104mm you'd use JE's or chevy pistons or whatever.
What are your leakdown numbers? And you're fairly sure the leakdown problems are rings and not valves?
Oh, you are going to try to bore and hone to 104mm and raise the silicon? Probably cost you more than an S2 or 968 short block (which comes with a crank and pistons.) 968 blocks have piston squirters too.
-Joel.
-Joel.
-Joel.
-Joel.
