New KONI Shocks = :)
Originally Posted by Skip
Because it is recommended that you put some oil, ATF or antifreeze inside the strut tube to aid in heat dissipation. Approximately 3 tablespoons full.
That is true only of the struts from the 86 951 and 87 944 on. Earlier rebuildable struts from the 83-86 944 and 924S use strut inserts - these do not have to be cut-n-drilled like the later models.
