Replacing mirror glass
So a couple weeks back I jumped in the car to drive to work, shut the door and the passenger side mirror glass just falls off and shatters on the cement.
I managed to find a relacement at the local junkyard, however I could not get just the mirror glass out...had to rip out the whole part that swivels and has the heated mirror contacts. Part number: 94473103506
Is there an easy way to install this whole part into my existing mirror assembly? When I swivel the mount from side to side I can see (3) bolts that would appear to secure this part, but I have no clue how to get at them with a socket. Do I need some type of special swivel head or bendy attachment???
Am I attacking this from the wrong perspective???
*on a side note I need another sunvisor clip too*
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
The glass is attached to a plastic piece, and you need to turn the little ring on the outside a couple mm either to the right or left with the tip of a screw driver. This will allow you to pull the glass/plastic piece out and disconnect it from the 2 wires.
Once again another over-engineered PITA!
The mirror is in and secure, but it certainly was not easy!
Thanks for your help! Tune in next time for when I wrestle the intake manifold to replace vacuum lines and do a venturi delete.
I'll be tackling a tb reseal at the same time! OH JOY!
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
The mirror is in and secure, but it certainly was not easy!![grr](https://rennlist.com/forums/graemlins/cussing.gif)
