A/C Fixed ... I hope.
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
If you remember a while back I posted a problem where when I pushed the A/C button it would blow the fuse almost immediately. I bit the bullet and bought the Griffiths Khuel system with the serpentine condenser. Finally got it all installed and charged last Saturday. I converted the system to 134a and it cools as good or better than the r12. the serpentine condenser also has the car running cooler now since more are is able to get through to the radiator. Life is much better with A/C! If it makes it to next Saturday I think I'll be convinced the fix is permanent! The Khuel compressor makes absolutely no noise when it is running and you cannot feel any drag on the motor. I am sure there is some parasitic drag on the motor but you can not feel it. Two thumbs up for a, thus far, great 134a conversion solution from Griffiths!
Originally Posted by Porsche-O-Phile
Sweet! You got a link to that kit?
