Small Vacuum line ....size?
Could someone tell me what size of hose is needed to replace the small vacuum hoses on our cars?
OD/ID?
TIA!
OD/ID?
TIA!
Originally Posted by KuHL 951
If you are talking about repalcing the hard black tubes I used 5/32" heavy wall vac line with 3/16" barbs. I pulled all that hard tubing out so I'm sure on the OD.
No the rubber ones that connect to those hard tubes. Elbows to the FPR etc. Thanks!
Jane Bond 007
I'd love it, but they already have Chuck Earhardt - the guy who LITERALLY wrote the book on evidence!
And the Gator thing was made by Testy for me when I complained about his "bias." I can't help it if others appreciate a good avatar
Hey Man
The 5/32" vac line fit all of the barbs(FPR, FD, banjo bolt, etc) but is too big for that hard black tubing. My tubing was so brittle it just crumbled in my hand. I think the OE size can't be any more than 1/8" ID if you don't go metric for a replacement hose.
JD.....Sad to say but it sounds like you could be kept very busy!
kuhl....Yep I am considering replacing the tubing because it is falling apart too it appears.
Hey Man
Jane Bond 007
It's really kind of funny.....
I bought the Lindsey vaccuum kit and wound up doing the venturi delete and cycling valve delete. I also have an EBC. In the end, I used less than half of the Lindsey tubing and NONE of the tees!
Care to unload those tees?
