my throttle body is sticking open HELP (now with pics and vids)
Old 07-14-2005, 10:34 AM
Headhunter
Headhunter's Avatar
This happened to me last year. The bearing inside get's munged up over time. There's no easy fix so you'll have to replace the unit.
Old 07-14-2005, 02:28 PM
F18Rep
F18Rep's Avatar
Has the car backfired recently - maybe could have bent the throttle shaft. OK, I admit it, it s a weak theory. I would certainly pull it apart though. The bearings are rollers and can be cleaned-up (even while they are installed), just have to get teh shaft out of the way.
Most times it is the disk being slightly mis-positioned (or flipped over) following a resal - that causes the sticking. That doesn't really fit your case though (you didn't mention anything about a reseal). A tiny amount of adjustment to the disk might be possible by lossening the screws just a hair. I can mail you a snapring, if thats holding you up - I have a few thousand laying around ;] ...Bruce
Old 07-14-2005, 03:57 PM
Cass944
Cass944's Avatar
well it looks like i need to find a TB somewere in northern IL southern WI right away. as in TODAY.
what was the name of that place in joliet that sells all the parts but has horrible service. I bought some stuff from there before bt i forgot what it was called.
Old 07-14-2005, 04:27 PM
MichelleJD
Jane Bond 007
MichelleJD's Avatar
I live close to Joliet if you need me. It may just be one of the o-rings deteriorated and is gumming up the works. Before buying a new one, take it apart (you've got nothing to lose at this point) and clean around the bearings well. Then replace the o-rings and see what happens. It's a cheap "what if" and keeps you moving forward while you look for another TB.
Old 07-14-2005, 04:42 PM
Cass944
Cass944's Avatar
I have had it sitting covered with lube oil for about an hour now... doesnt seem to be helping much. Tried some junk yards and they quoted 200$.
sheesh, heres some more pics.
here is the bearing that im thinking is the problem... i justhave a pool of oil sitting on top of it hoping it will free something up.
Old 07-14-2005, 05:08 PM
Mike Murcia
Mike Murcia's Avatar
Yank off the c-clip and take it apart to lube it up. It's not that complicated of a piece.
Old 07-14-2005, 08:14 PM
Cass944
Cass944's Avatar
after having it soaked with oil all day it moves freely again. i put it back on. works like new.
thanks everyone
Old 07-15-2005, 08:05 AM
pearldrum944
pearldrum944's Avatar
Awesome, see you there!
Old 07-15-2005, 10:50 PM
MartinT
MartinT's Avatar
I had the same thing with mine after ingesting water last year. I replaced mine with a used one from 944online. I have seen a rebuild kit on the net, but can't for the life of me remember where.
Martin
Old 07-15-2005, 10:57 PM
Yabo
Yabo's Avatar
I *THINK* frwilk may sell a reseal kit for the throttle body, it's on ebay sometimes..... not sure if thats who sold it thouhg.
Old 07-15-2005, 11:10 PM
Yabo
Yabo's Avatar
Sorry here is a link to a past auction....
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
It was arnworx not frwilk, i knew it was one of those guys.
Quick Reply: my throttle body is sticking open HELP (now with pics and vids)
