Fan won't shut off!
I'm at work right now, and it's a good thing I went out to my car to grab my sunglasses because I discovered that after 3 hours my fan was still runing. I started the car up and let it idle for a few minutes to charge the battery back up and then I disconnected the negative battery cable so the fan would shut off. What am I looking at? Temperature sensor? Fan relay? I noticed yesterday the fan ran for an extended period of time, about 20 minutes, but did shut off. Today was not the case.
_________
Pat
86 944
_________
Pat
86 944
Sounds like the fan switch on the radiator has went kaput. Do a search for Clarks Garage, there is a good section there on determining if it is the switch, and replacement.
Defending the Border
Rest In Peace
Rest In Peace
Mine craqpped last week. Replaced the fan switch after a continuity check showed the switch failed closed. Then when the fan did come on, both would run. Fixed that with a new relay. Luckly all this happened on a Sat.
Pulling the relay is good to get you back home.
I found the thermofan switch replacement instructions but it didn't mention how to test it.
http://www.clarks-garage.com/shop-manual/cool-05.htm
I pulled up relays on pelican parts. There is the "Multi-Purpose Relay" - for Fan, A/C Blower, Defroster, Fog Lamps, Horn, Starter, Rear Window Defroster, Fresh Air Blower which is $10 dollars, and there is another one that just says "fan relay" for $132.00 !!!
Which one would be the thermofan relay that i'm looking for?
Speaking of fans, just how are these supposed to operate on a normally aspirated, 1986 944? Should both run and should one or the other continue to run after engine shutdown? What is the proper operation for these?
mine did the same thing...in my case it was the $15 switch. In the mean time I found just pulling the fuse the simplest 'patch'. You can run without the fan fine, but if you get stuck in traffic, expect to pull over & put it back in. Also keep an eye on your temp gauge.
it can be either the thermoswitch in the radiator or the fan relay. Use the trouble shooting procedures at clark's garage to diagnose. The fan relay is expensive so make sure that is the problem before buying a new one.
____________________________________
1986 944 NA - Guards Red - 80k miles
1984 911 Carrera Coupe - Guards Red (gone, but not forgotten)
"If you're not living on the edge, you're not living"
I had the same problem it was the switch that goes into the radiator, I replaced it with one that came on sooner(Zims)...pulling the relay will, kill it. Just remember it is hot out there and that drive home may be fatal to your engine.
