Alternator replacement: tensioning
Addic
my bad, i was thinking all the way off... i only took off the power steering belt because the other belt wont come off otherwise because its behind it... forgive me, it was early
Hey guys, thanks for the help! I got it in and works good. I think my volt gauge is a little bit lazy because when I turn the key "on" it reads a tad below 12 and with the engine running slightly above 13.
Will test drive soon!!
EDIT: One last question. I think I read on a different thread on the list that to tension it by hand, you tension it until you can rotate the belt only about 1/4 turn? Thats about what it was before I took the old one off and is how I tensioned it today. Is that about right?
