AC charge, 89 S2 which fitting is low pressure?
My parents neighbor (80yr old former mechanic), has a couple spare 14oz bottle of R-12, and the small hose w/ the valve on one end. He says it's no big deal to add some freon, he still does it for his grandkids cars, and that ideally you'd use some pressure guages but it's not necessary.
I had been told that the fitting down by the compressor is 'low pressure', and the one up by the brake fluid resevoir is 'high pressure' (obviously add r-12 at the low pressure). But neighbor mechanic was looking at my car and wasn't so sure, -and I don't want to do it wrong! Anybody know for sure on an '89 S2?
-thanks!
-thanks!
Originally Posted by aribop
Unfortunately it's the one on the compressor. Doesn't make a whole lot of sense considering the one by the strut tower is much easier to get to...oh well!
I can get the fitting right on there, it points straight down and the fitting my old friend has just screws on straight. Maybe using the correct hoses makes it more difficult. Ok, so the low pressure side is just aft of the compressor and the high pressure side is up near the strut top. -thanks!
Originally Posted by 83na944
That fitting is hard to get to. There is a trick to make access easier by using a shorter belt. It was discussed in an thread last year IIRC. An "L" shaped adapter also helps.
Thanks!
Erich
Originally Posted by ErichCS
Do you know where to get one of these L Shaped Adapters?
Thanks!
Erich
Thanks!
Erich
