ONCE AGAIN need help ASAP
If you replaced the intake manifold gaskets, know they only go in one way due to the cutout for the fuel injector at the intake port. If you reverse the gasket, the "thicker" portion (circumferencewise, not thickness) will block the injectors. That won't cause too much problem but the thinner part of the intake manifold gasket sometimes "blow out" making a big hole between the intake port and engine bay causing a big vacuum leak and could cause the car to run like crap. The best test for this is to use a can of carburator cleaner with a straw and spray it where the intake manifold gasket is while the car is running. If the car runs better, then you have a vacuum leak there.
Originally Posted by KuHL 951
If you are leaving on a trip, I'd go ahead and send the injectors to Witchhunter for cleaning, matching, and rebuild. For $12/ea it's a steal and turnaround time for me was only 3 days. It made a world of difference.
Hey Man
It was a tough one to find
Anyway great company and service. They are in Washington State.
http://www.witchhunter.com
Steve
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Steve
well just got back from vegas. man that was a long trip i drove straight through 14hours back and forth. Have any of u guys sent stuff out to here before? i call the # and it is a wrong #
Steve how long ago did u send urs
Hey Man
I did mine about 3 weeks ago. The number I have on my receipt is 206 919-0794. They got them on Wednesday and I had them back Friday morning by paying an x-tra $7.50...I was in a hurry, they usually ship back 2-3 day USPS Priority Mail. It's hard to beat that plus they give you the before/after results.
Steve
Steve
Steve
i went out in the car and it started right up? then all of a sudden it died after idleing. i started it up again and gave it gas and choked a little bit then started reving fine then when it came back to idle it died again. i don tknow but this sound something wrong with the fuel. like it is getting stuck?
also another thing when it tries starting it smells like fuel could it be getting flooded. i know when i was working on the manifold i set the injectors on a rag and it must have leaked fuel out because there where fuel on the towel. I am planning on sending them to that place and hope that fixes them.
Backfiring? Timing-related. The vacuum leak only compounds this running problem. Pull out the fuel pressure regulator air hose, and remove the gas cap, then try starting it. This will ensure maximum fuel delivery, and chase any vapor lock out. Start squirting brake cleaner around the intake, and head area, to locate the unmetered air entry. Reset the DME for 10min, by disconnecting the negative battery terminal first, and foremost.
Zach
Zach
well i figured out that my air flow signal wire was loose LOL. well its running good but it seems like i am building boost alot slower then i used to. just need to figure it out.
