WOW! Fresh Paint!!!!! -----UPDATE!!!!>>>> MORE PICS!
#32
It looks like it is going back together very well! I really admire your accomplishment. I'm trying to do the same thing to my car, but I am not making the same rate of progress as you are. If I'm lucky, I'll have the engine compartment and various front-end sheet metal done in a month. $800 is very believable... I already have $200 in supplies and I have not even bought any paint yet (that does include some things like sanding blocks which are tools that you can re-use though). However, on top of that is the equipment: Remote fresh air supply ($350... you can also use an organic respirator but I preferred the fresh air route) Spray guns, dry air etc. But hopefully it pays off. Certainly it has in your case. I agree about the hard work. On top of all the prep is getting a good work area ready (I'm still working on my "booth"...). It really takes patience!
With Dan's help you also can rest easy knowing you did all the right steps. It was reading about Dan's job on 944Pete's S2 that got me started on this.
As a specific question, what did you do for fans/ventilation etc?
Thank you for continuing to post more pics, not only is it enjoyable to admire fine work, but it is also inspiring and helpful!
#33
Dan- looks pretty darn good, I'll post pics!
Allan- sounds like you have a serious project in store. For ventalation, my garage has a side door, so we just bought one of those big box fans, faced it out and opened the door. This really pulled alot of the overspray out of the garage, worked great in my opinion. Good Luck with the work. The more careful prep you do the better it will turn out, trust me.
#34
She just keeps getting better and better!!!!
I love the way the paint looks, keep having to go out to the garage to ask myself, is that really MY car???
It looks amazing, and will get only better w/ sanding and buffing.
#38
Originally Posted by Macfreak007
Edit: and that is NOT paint on the wheels, I promise!, just left over sanding dust!
and your time frame sounds like you did it right, 80-100 hours from what i can tell is what a good paint job takes, including proper setup, prep, hard work.
kudos, lookin nice
#43
Mac you better make this a DIY thread!!!! You truly have talent with these cars and with Auto Body! I'll PM you for tips on door jambs later because I'm about to redo mine myself since they are chipping.
Keep up the Excellent Work!!!!!
