MOMO Horn Button Problem (w/Porsche Logo)
I just replaced my steering wheel with a new Momo wheel and hub, but the horn won't work. I checked the connection between the steering column and the new hub and it appears to be making good contact as I bent up the metal thingy a bit. So, the only thing left I can think of is that the center button is defective. Anyone ever open the button up to work on it?? Anything else I should check? Horn worked with the old wheel...
my old momo button had two connectors I believe whereas the new porsche logo button had only one connector. I taped the other wire? to the metal ring as a ground and it has been working fine ever since...dunno if that makes any sense - Its been awhile since I did that.
I have a '84 and there is only one wire in the hub and the horn button only has one possible connection. I have no wire to use as a ground. What next or did I miss something?
