Rear fog lights
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
Odd thing. Went to change a blown rear brake light, and noticed the light sockets for the big innermost lamps on the rear light/indicator panels were empty. Took me a while to find that in the owners manual these are described as the rear fog lights. It even showed a picture of where the rear fog light switch should be on the dash. It would be beside the front fog light switch, which makes sense.
Now, on my car, there is no such rear fog light switch, so I assume that either it was optional equipment, or (more likely) a market-specific feature. My guess is that they might not even be legal in some markets. Anyone actually have these enabled, and where do you live?
I was toying with the idea of wiring them up to be an extra set of brake lights for the rear. Can't have too many brake lights to discourage those SUVs driving over the back of you...
Mostly idle curiosity. I probably have too much time on my hands to be even thinking about this...
-Mark
-Mark
My 98 Volvo still has a "rear fog" which illuminates the left brake bulb...Must be a European thing, like the parking lights lighting up on on side or the other with the car off and the turn signal stalk engaged to the right or left...
Are you saying they come on when the brake pedal is depressed? If so, that is 100% illegal and it is just a matter of time before you get pulled over.
Either way, rear fog lights are for ROW only. It is illegal in the US to have white light showing from the rear of the car (this is why it is illegal to have broken or cracked taillights).
You can get the wiring to wire them up correctly (I think IceShark did a write up on how to do it at some point) but why bother?
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
The euro rear bright red fog light (singular) was on the drivers side only. Has a faceted reflector to focus the light directly to the rear. IceShark had kits to add in the empty bulbs. You could use them for running lights or brake lights. You can add aux brake lights in most states as long as they are not too bright (blinding).
As the rear running/tail lights in the 944 lenses are somewhat dim I use the fog lights as running lights with a lower watt ratting bulb. Could use them as both with a dual contact base. I found and bought a bunce of bent up tal light backings in a now defunct 944 junk yard years ago.
83 944 = It's NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts
and/or cam chain and tensioner?
The 83
The 83
-Mark
-Mark
So you can do whatever you want on rearanging but I would turn the inboard cells into brake lights. And stick in some 35 watt halogen bulbs in them. SUVs will notice you when you hit the brakes, no problem.
I'm not doing the upgrades anymore as not many additional people want it.
They are red.
Mark
Rear fogs are very common here. My old Hyundai Exel had a fog light on the drivers side rear. Took me about six months to figure out how to turn it off!!!
But they sure make you easy to see in the dark!
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Originally Posted by beeg
Mark
But they sure make you easy to see in the dark!![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
-Mark
Mate
It was a bright white!
People used to ask me ' what the hell is the light at the back?' my reply (till I found out how to turn it off
) ' stuffed if i know'.
Check out an Exel.
It's in the rear bumper.
Check out an Exel.
Originally Posted by aribop
Beeg, when you hit the brakes, which lights come on?
I'll get someone to check me tomorrow.
1 Post
A lot of cars sold in the U.S. have rear fog lights. They are so other cars can see you as they approach you from behind in poor visibility conditions. They are all red, and are roughly the same brightness as brake lights.
Some such U.S.-spec vehicles, off the top of my head, include Alfa Romeo 164 models, Land Rovers, Jaguars, Oldsmobile Aurora. Ferrari 400i was imported available with factory rear fog in U.S., too.
Mark - I have the rear fog light switch in my car. I bougt it from Gabe at Strasse for around $50. Had to import it from Germany. I discovered the usefulness of rear fogs several years ago when I was driving in misty windy rain and there was so much splash around that you really couldn't see other cars. I have yet to add the lights in the back of my car. For now, my rear fog switch allows me to disable the front *driving* lights I installed, so I don't always have to have them on with the high beams.
The rear fog light switch for the 944 has an amber LED instead of a green one, and the lamp icon faces the other direction, with a different pattern of squiggly lines coming from it, FWIW.
EDIT: Also, white auxiliary lights in the back of a car are to aid in visibility when backing up. If you have ever found yourself in a dark, unfamiliar place and had to get out of the car to make sure you weren't going to back into anything, then you have witnessed the usefulness for such items. They are more common in rural areas and among vehicles that travel in the wilderness.
Cheers,
Tony
Cheers,
Tony
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
hey guys I've noticed this on an SLK once with the running light on. Why do they only put it on the driver side? is it to warn other drivers of a car on the side of the road?
