T belt replacement, crank pulleys off or not?
Old 05-12-2005, 11:54 AM
josephsc
josephsc's Avatar
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
Originally Posted by Jfrahm
With an S2 you need to take the pully off (in case some S2 people are reading this.)
I found the same with a 968 motor -- not fun, b/c getting the pulley back on takes alot of torque.
Old 05-12-2005, 01:07 PM
Legoland951
Legoland951's Avatar
Make sure that lock nut is not in the timing belt compartment.
Old 05-12-2005, 03:09 PM
Scott at Team Harco
Just a car guy
Scott at Team Harco's Avatar
Originally Posted by Homer
Y'all,
Thanks for the replies..no problem at all getting the belt onto the gear, if you start from beneath on the PowerSteering pump side, it slips right in, a bit of wiggling gets it in. No risk to twisting or damaging the belt that I could see. Now, if I could only find the lock nut for the tensioner I dropped!! I cleaned up the inside of the belt housing and cleaned and inspected the rollers, tensioners. I was replacing the cam belt tensioner anyway. I think the bolt might have slipped into the fan shroud, but I didn't see there or on the floor...I hate when that happens!!
Doh!
Sorry, couldn't resist - Homer...
Old 05-13-2005, 03:28 PM
Homer
Homer's Avatar
Well..she's all back together..never did find that nut..did stop by the dealer and buy 3 of them..just for future disappearances :-) Would have just used a plastic sleeved lock nut, but didn't want to rile the OEM Porsche God of Belts!!
thanks for the replies
Quick Reply: T belt replacement, crank pulleys off or not?
