Paint advice
Paint advice
I've attached a picture of the 928 I'm considering buying. The body is in excellent shape, except for the passenger side door, which seems a different color. I think there is some sort of problem with the clear coat maybe. If this is indeed the issue, what needs to done to correct the problem. Will the entire door need to be stripped and repaint/clear coated, or can something simpler (less expensive) be done?
Thanks in advance.
Thanks in advance.
i agree, it seems as if the rear bumper and door are one color, while the handle, rear quarter, and fender are another. A good paint shop should be able to strip it and blend it to match the current color.
