Help diag this noise, rattle
I identify that the rattle comes from the clutch housing area , where theres a hole you can see in, but i dont see anything out of ordinary, the rattle is amplified into the cabin thru the gear ****, the rattle is not exactly rpm dependent,and it doesnt happen all the time. It happens with or without the clutch pedal depressed, and the clucth feels normal, no excess travel, or spliping.
Does anyone kwon what this might be?? Similar experiences??
At first i thought it was a heat shield or a loose exhaust, but everything is tight very good
Any thoughts??
Any thoughts??
