944 parts help
I am looking for an a/c line for my 1987 944 n/a. it is the high side line that runs from the evaporator to the reciever drier. runs along the firewall and across the left side of the engine compartment. I was attempting to convert mine to 134a and the fitting snapped off the line.
Also does someone know the napa belt or length of the belt used to get added clearence at the compressor when converting to 134a..
thanks in advance..
DAVID
thanks in advance..
DAVID
you have to get a longer belt when converting to 134a? you should be able to change the fluid and recharge w/ 134a w/ new seals. I wouldve had the line a month ago but that car is gone.
I have the line. It came off of a car that had good working air before it was wrecked. It still had a lot of pressure on it when i took it apart.
Drop me a line
toddandcharity@peoplepc.com
Thanks.
Drop me a line
Thanks.
