stripped seat bolts
Stripped seat bolts
If you are talking about those L shaped brackets under the seat rail the bolts screw into, they look pretty common in size. If someone here has the dimensions Im sure any hardware store will have them.
Id rather give birth through my rectum than mess with stripped seat bolts again.
Thefu
Correct mounting bolts (late): http://www.classic9leathershop.com/s...inc-1985-1998/
(early): http://www.classic9leathershop.com/s...nc-1970s-1984/
My recollection is that the bolts have shallow heads. So a regular allen might run into clearance problems. Not certain.
Thefu
