Dynatech Strut Brace - buy one with me for a discount
#61
Hi 944 Fanatic,
I'm interested in the dynatech strut brace,but I have a couple of questions.
First will the strut fit the 968 ?
Who do we send the money to ?
Lastly will the brace be shipped directly to each individual
#62
Originally Posted by 944 Fanatic
Thanks David. You meant 'asynchronously.'
Daniel, what do you mean "ok" ?? I must have missed an edit there.
#64
Hey Guys,
Sorry I've been out of pocket. The Offshore Technology Conference has been going on the last week here in Houston. For those of us who work in the offshore oil and gas industry it is the busiest week of the year.
I've got a few questions stacked up, so I will start with the most recent:
The strut brace is an excellent fit on the 968. No modifications are required. It only takes about 15 minutes to install if you read the instructions first and have all of your tools on hand.
We will ship direct to each customer. We will discount shipping and handling for ground shipment in the continental U.S. to $10, for a total on the strut brace of $295. We will also do S&H on the camberplates for $10 (slightly below cost in both cases).
Since there are many shipping points for the interested customers on this group buy which Vinay has started, we will ship each order direct to each customer. Another week or two should be sufficient to finish compiling the group buy list, so we'll call the deadline Wednesday, May 18, at 10PM CST.
As for payment: cash, check, money order, or credit card. We are currently processing our credit card orders through Paypal, but we should have a direct merchant account set up within 2 weeks.
The camberplates are compatible with stock springs and there is no change to ride height. A special spring perch is required. For the group buy special, we will sell the OEM-type stamped steel spring perches for $30/pair outright, or $10/pair exchange with a $20 deposit. We have aluminum spring perches for 2-1/4" and 2-1/2" ID racing coils for Koni, Bilstein and Leda. Check for others.
The plastic cover on the camberplates is of course removeable, we use it to keep moisture and dirt out of there for street use, which could lead to reduced spherical bearing life. There is a fair bit of space under the plastic cover to accomodate the long spindle threads of the Leda shocks, but I don't think there is quite enough space to allow the cap to go all the way down. However, a small whole can easily be cut through the plastic cap to still shield nearly all of the opening.
BTW, the Guru racing camberplates appear to be high quality pieces. Like other camberplates, though, the spherical joint is rigidly mounted within the housings that attach to the car. That design definitely eliminates lateral deflection of the bearing, but it also transmits ride harshness and shock loading into the vehicle chassis. Do any of you guys have CD players/changers?? Think about it...
Our patent pending Streetable Camberplates provide the same handling performance of racing camberplates, without the harsh ride. This technology is only available for Porsches at this time, although we are also looking at other applications. Next up: 993/964.
That's why our camberplates are more expensive. They are more complex, with a few more pieces, including these excellent polyurethance bushings that we were custom-manufactured for us in Germany. They actually cost us more to make, than the price that Guru sells his camberplates for. But if you have great roads where you live, or you only use your car on the weekend, his product is a good choice that I would recommend.
To 944 Fanatic, we are 99% certain that our camberplates will fit 85.5-86 944's, but we have not had them installed yet. As first adopter on this model year, we will offer special discounting and a 100% guarantee. I will send you a PM to discuss further.
To pass on a little info on the pricing, the reason the prices seem high boils down to two things: low manufacturing volumes and extremely, high quality, custom CNC-manufactured parts made here in the USA. For you Rennlisters, we will also throw in a show-quality polish job for those who want the polished finish rather than the low-key satin racer look. You look at some of these parts and think that they are a work of art. Just wait and see...
Sean
Dynatech Motorsports, Inc.
http://home.earthlink.net/~968/index2.htm
Sean
#68
John,
I just spoke to the Guys at Lindsey and was told that there is no difference in the height of the Lindsey fuel rail and the OEM Porsche fuel rail, if the information that i was just given is correct, we should have no problems at all,
Scott
Scott
Originally Posted by painkiller
Will the strut brace fit on a 951 with a Lindsey fuel rail?
TIA
John
TIA
John
#72
Paul, if you could check that out I would be grateful. Just would like to be sure and not be disappointed because that strut brace is the nicest I've seen.
Scott, assuming no interference issues count me in for one with the full polish finish.
Hex, thanks for initiating this. Looks like a fabulous piece.
John
John
#74
This strut brace count looks like
1. hexdriver
2. 944 fanatic
3. Bill
4. amex859
5. painkiller
That's five so we are ready to go. Hopefully, Sean will chime in today and tell us if dynatech is ready.
Thanks everyone!
vinay
1. hexdriver
2. 944 fanatic
3. Bill
4. amex859
5. painkiller
Thanks everyone!
vinay
#75
Rennlist Lifetime Member
Painkiller, I verified that both the Lindsey and the stock fuel rail are the same size. Both measure at just a hair under 3.5" from the intake manifold mounts to the top of the rail. Should be no problems.
I'm still in on a set of plates and a brace.
