noob brake pad question
I'm going to be doing brake pads all around pretty soon, and I'm concerned about what brake pads I should buy. I do know that there are some types of pads that once they are used on a rotor, the same type has to be used again due to how the pad works(rubs it's own material on the rotor or something.)
How do I tell if those type of pads are on my car right now? Can I just slap a pair of metal masters on and be done with it? Are there any other items I should be concerned about?
OE are quite good and will give very good rotor life. Unless you're doing tons of track driving, there's really no reason to go with anything different.
I've heard the metal masters kind of suck and will tear up your rotors more quickly than the stock ones. It's a Porsche, not a Chevy Nova. Don't be so cheap. Brakes are your friend.
Forgive my smart-***-ness but seriously, if you're concerned about cost, consider that you'll either pay a bit today or a LOT next time to replace pads and rotors. Do it once, do it right. Check the rotors also and if they need replacing or resurfacing, definitely do it. Good luck.
I wasn't suggesting metal masters because I'm cheap, they were just the first pads that came to mind.
But I can safely put a pair of OE pads on? The rotors are all good.
You bet. They're very easy to do on these cars. You'll need (in addition to brake cleaner and a couple of good pairs of gloves) the replacement pads, a small hammer, a good pair of gripping pliers, a couple of screwdrivers to pry with and spread the caliper pistons with, some wire and that's pretty much about it. Changing all four sets of pads including putting a micrometer on th rotors (which should be done at eight points around normally to check for proper thickness) takes no less than an hour once the car is on jacks or a lift with the lugs loosened. It's cake.
You'll love your 944 even more when you see how simple and easy the brakes are.
Get PBR Deluxe pads. Easy on rotors, low wear, and little dust. I had them on my 944.
They are very cheap from Vertex - advertised prices: 30 front/ 29 rear.
Friendan, ClarksGarage has alot of good info about brake rotor thickness...
http://www.clarks-garage.com/shop-manual/brake-04.htm
