Proper Oil Pressure?
Does anyone know what the normal oil pressure is at idle, and at 2500 rpm?
I am sitting at 90psi idle 120psi at 2500-3500 rpm.
Thanks in advance
Thanks in advance
Fully warmed up, the oil pressure should be near 2 on idle. By 2500 rpm, around 4 bar. Oil pressure should not go higher than 5 bar, fully warmed up.
90 psi is 6 bar. You have VERY VERY high oil pressure.
Changed it out with an older unit, and checked the new one, they seem to be working normally. I think the cooler may be clogged, and/or ruptured. See my post on the "other" oil pressure woe thread.
