Computer managmet system for 944 and 951
Old 04-20-2005, 04:37 PM
guido944
guido944's Avatar
Default Computer managmet system for 944 and 951
That somebody know what is? and what does this system do ?somebody tell me!!! my mechanic said is a computer managmet system that replace the stock ecu and delete the coil and rotor? and this computer system comes with two racing coils and tell how many times shot spaks and distribution system!!!and that you can set power or boost? it is true??and you can set for work in normal 944na or set for 951?where ia can find this system in usa ? what company sale it? my mechanic had one he try sale to me in 1600 dollares but i want to see if i can get it less expensive here in usa with a company ??can somebady tell more about this systems how works? ?if is relaible? and where get it??thanks alot guido
Old 04-20-2005, 05:21 PM
WesM951
WesM951's Avatar
Umm I think he's referring to a TEC III type setup. I have no clue as to what it cost or how hard it is to maintain. Basically a computer usually a laptop replaces the stock stuff and is fully tunable.
Old 04-20-2005, 05:31 PM
streckfu's
streckfu's's Avatar
There are two brands that are commonly used on the 944s MoTec and Electromotive. The Electromotive Tec3 is popular and less expensive than the MoTec but has less features. Both are stupid expensive on otherwise stock or mildly tuned cars. Definately not worthwhile on a street NA.
Spend your money elsewhere.
Old 04-20-2005, 05:34 PM
Geo
Geo's Avatar
Don't forget MoTeC.
Old 04-20-2005, 05:40 PM
streckfu's
streckfu's's Avatar
Originally Posted by Geo
Don't forget MoTeC.
Mentioned.
Old 04-20-2005, 06:37 PM
OK944
OK944's Avatar
Has anyone ever had luck with simple fuel computers?
Old 04-20-2005, 06:40 PM
L8 APEKS
L8 APEKS's Avatar
OK944, I'll have feedback on the Apexi S-AFC Select soon.
GUIDO...you don't want/need a stand-alone system. Forget about it.
Old 04-20-2005, 06:43 PM
OK944
OK944's Avatar
Hey Sean, your running a S-AFC right now? If so that makes me warm and fuzzy with the thought I might be able to get an E-manage to run adjusted fuel maps on one of these, then of course leading towards me throwing a couple PSI via an Eaton M90.
Old 04-20-2005, 06:45 PM
Danno
Danno's Avatar
There's no thing as a simple fuel-computer. I've had great success with the Apexi S-AFC-II interceptor. Does semi-3D mapping with LOADxRPM reference points. Really fast to make adjustments in 2-3 seconds at a stop-light...
"my mechanic had one he try sale to me in 1600 dollares but i want to see if i can get it less expensive here in usa with a company ??"
That price may make it a DTA or Autoronic system. Don't forget to add in $$$ for a new harness, crank-position sensors and triggers, cam-position sensors & triggers. Not to mention the labor in installing it. It'll also need a couple thousand dollars in dyno-tuning as well. In the end, you're looking at around $5000 at least.
And the power and performance will be identical to an appropriately programmed stock Motronic system. That's because if you're a piston sitting in the combustion chamber, you have no idea what is turning on and off the injectors and dumping the coil. It could be an aftermarket EFI system, the stock Motronic, or a chimpanzee flipping toggle-switches by hand! As long as all three systems turn on/off the injectors and fire the coil with the same specs., power-output will be exactly the same...
The system that I'd really like to see is a Palm-based EFi system. Just an adaptor harness to hook it up to the car, then everything is done in software. Then when you arrive at your destination, you just take it with you. Serves as an anti-theft system as well.
Old 04-20-2005, 07:04 PM
OK944
OK944's Avatar
I ran a nice Greddy E-manage setup when I turbo charged my Impreza RS and was in love with it since it had a support tool in which to program 16x16 maps on my laptop. I also installed a S-AFC on a WRX and wasn't as impressed for the mere fact I had already worked so much with my e-manage.
I don't suppose you did some kind of write up on installing the Apexi unit. It was straight forward on a WRX, figure it probably would be with a pin out diagram on the 944.
Did you ever see the Utec's with the Game Boy Advance adapters?
Old 12-04-2005, 04:42 AM
MM951
MM951's Avatar
Sorry to bump an old topic, but has anyone had luck with e-manage on the 944? Does anyone know even if it even works with the 944 AFM, wiring (early car)?
Mike
Old 12-04-2005, 05:51 AM
beeg
beeg's Avatar
Who let Guido back in?
Old 12-04-2005, 10:41 AM
Chris_924s
Nerd Herder
Chris_924s's Avatar
Brian- old topic, old thread- If you look Guido is still listed as banned.
Old 12-04-2005, 04:48 PM
beeg
beeg's Avatar
F***! I've gotta start drinking less!!
Old 12-04-2005, 05:20 PM
Gator_86_951
Spell Checker
Gator_86_951's Avatar
That solution is never acceptable.
Quick Reply: Computer managmet system for 944 and 951
Top
Follow Us
