compression test...what to look for?
Wax On, Wax Off
What numbers should I look for when doing a compression check? 1987 944.
should I look to make sure that all are very similar across all 4? is there a specific number? thanks!
Wax On, Wax Off
Ok. this car is consistant in all 4 cylinders around 150. runs smoothly, and leakdown (i didn't do an official test) is nice...I watched the compression go down on the gauge for 10 seconds, and it really did not move too much in all 4 cylinders...
So, my advice to my friend, BUY IT!!!!
Wax On, Wax Off
Ok, our tester is a cheap little $5.00 thingy got at auto zone... so I'm not expecting accuracy, but it did read consistant throughout all four cylinders...
and that was on a cold engine with an airbox...
Best I was able to do was mid to high 160's across all 4 cold. I was told that warm I should get close to 170+. Haven't tried that yet. Still working on the '83..
Michael
Michael
Anything in the 170 to 180 range is considered good on a 2.5 ltr NA engine. Anything under 140, and you probably start seeing oil usage and a loss of power. Inconsistencies between cylinders and you should do a real leakdown test (sorry, dude, but watching how fast the compression gauge goes down doesn't qualify!
) to determine what needs to be rebuilt.
Regards,
Regards,
Wax On, Wax Off
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
