968 CS suspension
1) 968 CS / 968 Lux without M030 :
a) Springs
- Stiffness : 28 N/mm, constant
- Length : CS 324 mm / Lux 348 mm
- Diameter : 106 mm
- Wire diameter : 11.6 mm
- Color code : CS blue dots / Lux beige dots
b) Torsion bars
- Diameter : 25.5 mm
c) Sway bars :
- Diameter : 26.8 mm front / 16 mm rear
2) 968 CS / 968 Lux with M030 :
a) Springs
- Stiffness : 28 N/mm, variable
- Length : 329 mm
- Diameter : 124 to 110 mm (variable)
- Wire diameter : 11.7 to 12.2 mm (variable)
- Color code : white and yellow dots
b) Torsion bars
c) Sway bars :
- Diameter : front 30 mm / rear 19 mm (manual) or 18 mm (tiptronic, Lux only) adjustable
I'm just quoting my own Suspension summary.
To sum it up, the CS standard suspension is merely a Lux standard suspension with shorter springs and set lowered at the rear from the factory.
A CS with M030 will have the exact same suspension specs as a Lux with M030.
a) Springs
- Diameter : 106 mm
b) Torsion bars
c) Sway bars :
a) Springs
- Length : 329 mm
b) Torsion bars
c) Sway bars :
Originally Posted by pete95zhn
And where's the M030 rear helper spring??
I don't know about the rear helper spring, sorry.
Originally Posted by J Chen
Hey Pete, multiplied figure is equal to only
160lbs. Can this be right ?
Speaking of which, whose calculation are more accurate ?
Paragon tech article works on 56% while others have
mention 60-65 %. So where do we go from here ?
https://rennlist.com/forums/showthre...ht=.65+paragon
https://rennlist.com/forums/showthre...hlight=.65+.56
Former Vendor
With those figures wheel rates front to rear are 25,2 N/mm* and 44,3 N/mm* ,but then there's 30mm and 19mm anti-roll bars equalizing heavily springed rear.
(* 90% eff. )
(** t-bar + 17,5 N/mm helper,65% eff. )
Originally Posted by MTM
I have those on my S2. From what I've heard, the helper springs are about 120 lbs/in and are 60-65% effective at the wheel, so that's like 70 lbs/in.
And one source says 100lbs/inch = 17,5 N/mm.If it is 120lbs/inch,the set-up is even more rearward biased.
Former Vendor
Originally Posted by Thom
In your a** !
(sorry, that's cheap french humour, but I couldn't resist).
I hereby resist my willingness to comment french perversions...
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
