tach will not function
ok when i first got my car the rpm or tach would not move at all sometimes it would sporastically move but it would never keep moving...ive tried taking it out and making sure all the connections were good but it did not help at all...ifd anyone could help me on this it would be greatly appreciated
My S2 had the same problem when I bought it. I took the tach out and could actually see one of the larger resistors had a fatigued solder joint. I reflowed the entire circuit board and the tach is rock solid now. Hope this helps.
I just went thru this with my project car (early '85). Tach wouldn't work at all. It turned out to be a broken wire at the 9 pin connector in engine compartment against the firewall. Theres two green wires in pin 1 of that connector. The larger green comes from the DME going to the coil. The smaller one in there is a back feed into the car to the tach. The small one was broken on mine. Check that connector/pins/wires there. Good luck
Originally Posted by chimmay
i have a 84 na 944
As to your question; the early tachs sometimes take the big one. You need to try one that works.
