Car cuts out for no reason?
So my car decided to suddenly cut out twice today, once when starting from a stop and once right after stopping. The second time it would not start again for a couple minutes. It would just crank and crank, then one time I tried cranking it it started up without a problem.
I tried starting the car again 1-2 hours later to go home from dinner and the same thing happend. Cranking as if there's no spark or fuel, then working perfectly all of the sudden.
My thought is I bumped something I should not have this last weekend when I replaced the O2 sensor and the small fuel line on the fuel rail. Aside from today the car has been running great since then, better then ever with the new O2 sensor. Any ideas what I should take a look at on it?
try wiggling the wires that plug together right next to where the o2 wires plug together. Those are the reference sensors. Mine had corrosion and would cause it to not start every once in a while, crank crank, then finally start. Next time it doesnt start right away, smack those wires and itll start. If so they need cleaned up. CAREFULLY>
Could also be the fuel-pressure. A bad FPR will increase fuel-pressure to the point where the injectors are locked and can't open to inject fuel. The pressure leaks out when the car's stopped.
i jiggled my 02 sensor plug around and never had a cutting out problem again. and no it wasn't because i touched the speed or reference sensors. i tried jiggling those forever and it never helped.
Replacing the crank sensor solved the problem in my case. ($$$)
Thanks for the suggestions guys. I think it's a touchy connection on one of the reference sensors. The car was sitting for an hour or two before cranking it, so it's not the FPR and I put in a spare DME relay before trying again and had no luck.
It started up shortly after I disconnected/reconnected the O2 sensor and generaly moved everything around back there. I guess I'll clean up the connections and make sure I didn't crack anything tonight.
