Wierd Idle Issue
Searched, nothing found - here's the issue:
After the car is warm, and I stop at an intersection, the car idles at about 1100RPMs. Then it drops to about 750RPMs for a second, then right back up to 1100. It does this rhythmically evey few seconds. If I tap the accelerator, it stops until the next time I'm at a stop light. It's pretty annoying. What do I need to adjust/replace?
TIA - Jonathan
TIA - Jonathan
its weird, my car did this yesterday too after warming up.. i started getting a hunting idle in nuetral.. then i drove it later and it was fine.. wtf? i remember it happening one other time like a year ago.. and nothing has changed in my car since then and now.. why is it so random? at least for me..
UAE Rennlist Ambassador
Under the intake, you can take it out without removeing the intake (like i did) and clean it out with engine degreaser.
remove the plug wires to gain more "room" since the mounting bracket gets in the way or virtually everything.
Mine does exactly the same thing. After driving for a while and stopping at a stop sign or to park in the parking lot. When it's not doing that, it regularly hunts for + or - 100 RPM while at idle. It seems to be worse when the air temperature is 25 F or less. I hope somebody can figure it out.
Vacuum line or intake manifold gaskets. Look to see if the gasket has squished out from under the maniforld. You can listen for it with a piece of small tubing with one end in your ear, like MDs do.
Lou
Lou
