Blaupunkt equalizer - how to remove?
I would like to remove the Blaupunkt equalizer in my 944 Turbo S to install the cubby hole below the radio. I can get it partway out, but it sticks, and I don't want to break it. What's the trick in removing it? I have the tool for removing a Blaupunkt radio, but the equalizer doesn't have the little holes on the side for pulling it out. Any expert advice would be appreciated.
I just took the EQ out of my '87 NA. The bezel has a spring clip on either side, and a third spring clip is mounted to the cross brace under the unit.
To get the EQ out you need to pull the radio, and then push the EQ out from the back.
Charlotte944, that's just the information I needed. Rennlist rocks. Now all I have to do is figure out how to get the radio out. If I recall, it's a Kenwood - with a light show I can't stand.
Sorry, I don't know if the eq works; the lights don't turn on, so I assume it's disconnected.
