944S with serious vibration at 3500 - 4000 rpm
#31
I would have to concur with the balance shaft theory. Mine was out 180 and it would buzz so badly that my hand would go numb if I left on the shift ****. The definitive diagnosis would be to take the BS belt off and then drive it. From what I have read the motor is actually fairy smooth without it, compared to being out of adjustment.
#33
Solved!
Wanted to add some closure and gratitiude to this thread. My 944S is back home after nearly a month with the doctor. Among the repairs were:
New motor mounts
Fixed driver's side door lock
Several dent doctor repairs
New hood strut
New coolant overflow tank
Most importantly, my vibration is history.
Thanks to your insight and advice, the problem was traced to a missing Woodruff key in the upper balance shaft. Now, 4000 RPM is a good place to be.
Appreciate everyone that contributed to the thread and got me back on the road.
Tim
New motor mounts
New hood strut
Tim
#34
So the belt pulley was slipping on the shaft giving the same indications as mounting the pulley 180 degrees off. Missing, somebody was in a hurry and did it wrong!
Glad to hear it was not the clutch.
#36
Originally Posted by jonnybgood
Tim, Take a good look at the pictures in this link. This is what Micah is talking about.
Tensioner Failure
Tensioner Failure
glad to hear you got things worked out. your S is a beauty - i'm envious.
#37
Originally Posted by joseph mitro
aaaaaa, memories of pain........
