Removing stub axle nut
Working on doing my rear rotors/bearings and I am having trouble removing the stub axle nut.... I know that this is a problme for alot of people. Anyone found a really good way to get it off yet??
I had that same problem with my '87. I broke a 3/4" breaker bar trying to get the axel nuts to break loose. I even bought an air impact gun, but even that didn't work. I finally took the car to a local Tire Kingdom. Gave them the socket I was using and for $10.00 they broke the nuts loose. I torqed them by hand, and drove the car back home. The rest was easy.
For pulling the bearings, I highly recommend heating the trailing arm and using a bearing puller or a hydraulic press. The bearings are pressed in when the trailing arm is hot, and getting the bearings out and back in can be a real PITA. To make installing the bearings easier, store them in a freezer.
Hey Man
I use a cheap $9.00 24-inch Harbor Freight breaker bar with a 1-1/4" x 36" cheater pipe. Haven't broken a breaker bar or impact socket yet. I used my ample weight to push down on the bar and it was easy. Set the parking brake, chock the wheel, and have someone stand on the brake pedal, it helps.
Hey Man
