charcoal canister?
UAE Rennlist Ambassador
Originally Posted by Techno Duck
Goes in the drivers side fender, just behind the wheel. I believe it is meant to elimnate any fuel vapors entering the cabin. I could be wrong though.
You are right.
Apparently the charcoal depletes itself over time and the cannister needs to be replaced. Buying a used one doesn't make sense to me. Luis De Prat did a write up on changing this.
it prevents fuel vapours from exiting the system into the atmosphere (cabin included)
it was purely an environmental addition from my understanding.. there is no performance gain, and other than extra weight, no performance loss either.
Originally Posted by Perry 951
Why not? It's better for the environment and it's a $34 part.
Buy a new one. I have a reciept right here for a new one from Paragon, 12/2002 for $34.59. You are correct, the charcoal gets saturated over time and cannot absorb the fumes. The whole operation (solenoid, temp sens, vac valves) is designed to suck off the fumes when the car is over 160 degrees and in low load. It's designed to remove the vapor from the gas tank when it becomes pressurized by temprature and fuel level changes. Simply environmental... like a catalytic.. something everyone should be running.
