944 Fuel Rail
944 Fuel Rail
Hi
On my 1987 944 there are two units that I would like to understand the function of. They are situated next to the fuel rail and seem to have a small pipe on one side with a high pressure fuel pipe on the other. They are marked BOSCH.
The reason I want to know is that when the engine is switched off, the front one seeps a little petrol. This seems to happen only when the engine is switched off, not wen running.
Does anyone know of a solution?
Mike
Mike
Simple tools to replace the FPD: Click Here
If it is the pipe that leaks, then don't drive the car at all!!! risk of fire!
But it could be the small pipe that runs on the fuel rail, still risk of fire.......double check
I replaced my fuel pressur reulator on the weekend and ended up having to take the entire fuel rail out of the car (no big deal but a PIA) and put it in a vice in order to get the retaining nut off the bottom of the FPR, even then I needed to use a length of pipe on the socket bar.
The PO or mech that installed it must have thought it was holding the whole car together!!
