How much does a 951 motor weigh?
Here's the deal, driving to N.C. to pick up a 951 drivetrain from Ian this weekend, and was doing some quick #'s on if I'm going to kill my truck. The truck has a [EDIT: 1461lb] payload capacity. Here's what I'll be bringing:
2 adults (both small): 300lbs
1 951 transmission: 100lbs
1 951 torque tube: 60lbs
crapload o'tools: 200lbs
jack & stands: 150lbs
total: 810lbs
I guess my question is....How much will the engine weigh?
i.e. when I add it in, will I be well over weight?
oh...btw...I'm getting the 'super-long-block'. i.e. block/head/turbo/exhaust/intercooler/wiring/hoses/dme/klr/etc.
total: 810lbs
951 DRY Engine Weight
It depends on what ancillaries the motor includes. According to Porsche- the basic
8V 1983 944N/A motor weighs 368lbs, with flywheel, NOT including the power steering pump, clutch, pressure plate or bellhousing. On the exhaust, the cast headers are factored in. For the induction side- this figure includes the 944 N/A curved intake boot, throttle body and manifold. According to Porsche- the 951 powerplant is 39lbs more than the engine mentioned above. Weight gain of the turbo, plumbing, and related components(intercooler, piping, and cycling cooler, tubing, etc.) only adds a degree of protection for an otherwise powerful, lightweight engine. The spring-loaded clutch components and bellhousing figures are below:
944 N/A 225mm clutch, pressure-plate, T/O bearing, Bellhousing/sensors=24.6lbs
944 Turbo 240mm clutch, pressure-plate, T/O bearing, Bellhousing/DME=25.5lbs
...According to Porsche- the basic
8V 1983 944N/A motor weighs 368lbs...
Where exactly did you see this information from Porsche? I would be very interested in seeing more (e.g. weight of a 996 motor, etc.).
TIA.
Karl.
I weighed my engine when I had it hanging from the rafters. Turned out to be about 440lbs without fluids. It was a longblock+extras like alternator, power-steering-pump, headers, intake-manifold, turbo, etc.
