Delrin sway bar bushing?
Old 02-01-2005 | 12:40 PM
skene's Avatar
skene
Default Delrin sway bar bushing?
My passenger side front swaybar bushing is shot and I'm thinking of replacing both of them with delrin bushings. I checked Paragon's site and noticed the smallest ones they have offer are 25.5mm. Since I've got an '86 with a 24mm swaybar (I measured it to be sure) are there any alternatives to the rubber bushing?
Old 02-01-2005 | 01:16 PM
Mike Buck's Avatar
Mike Buck
Andrew,
sent you a PM regarding other options
thanks
mike
Old 02-01-2005 | 02:03 PM
skene's Avatar
skene
Thanks Mike. Reply sent
Old 02-01-2005 | 03:16 PM
jurg's Avatar
jurg
Andrew look a this site
http://www.powerflex.co.uk
Old 01-22-2007 | 07:05 PM
dnwong's Avatar
dnwong
Any dealers for these bushing in the US?
Old 01-22-2007 | 07:32 PM
Wipeout's Avatar
Wipeout
Not Special
Only slightly off-topic, my passenger side sway bushing is out as well. How do you get the new one on? I don't really feel like loosening random nuts and bolts attached to my suspension to figure it out!
Old 01-22-2007 | 07:45 PM
Techno Duck's Avatar
Techno Duck
If your talking about the regular rubber bushings, you need to loosen the clamp and take the droplink off on the passenger side control arm. With some soapy water you can then slide the new one on the end of the bar. Its alot easier if you take the entire sway bar off.
Old 01-23-2007 | 03:30 AM
Mike B's Avatar
Mike B
Done With Sidepatch
Originally Posted by Mike Buck
Andrew,
thanks
mike
I'll bite Mike...What other options?
Old 01-23-2007 | 10:39 AM
sca037's Avatar
sca037
Yes, I'm interested as well
Brian
Old 01-23-2007 | 11:57 AM
skene's Avatar
skene
His other option was to buy a larger set of bars with new bushings off his parts car...but as far as I know he only had one set available
Old 01-25-2007 | 01:01 AM
CO951's Avatar
CO951
I have some 951 M030 sways for sale, if anyone is interested.
