Amp Placement
Originally Posted by my87944s
how about in one of the side cubbies? in my previous 944 I built a slide-in/out amp board and mounted it in the passanger side rear cubby. It was a fairly small amp, but I think you could fit something rather large in there...
I bought my 86 new without the stereo (it was a $400 option back then). However, the car did come with the door and backseat speakers with the fader control mounted on the center console forward of the shift lever. I opted not to get the factory stereo knowing I wanted to spend some dollars in an aftermarket, professionally installed system. In short, I had installed a Nakamichi system consisting of separate componets (speakers and amps). Two amps were installed (one for the 8" SP80 subs and one amp for the tweeters and mid-range SP10s and SP50s). Both amps were mounted on a piece of plywood and mounted in the left side (drivers side) compartment in the rear. I was initially concerned about overheating problems; but never experienced a problem. My stereo lasted 10 or so years and then the amps started having problems. I replaced them with other make amps that fit the dimensions of this space. Earlier this year, I had to replace one of the 2 again. So I'm averaging 8 - 10 yrs on my amps living in this enclosed compartment. The Nak subs reside in a custom-made enclosure wrapped in black carpet that sit on top of these compartments (both sides). The enclosures fit that cavity space well. Overall appearance is pleasing. I used a instructional guide by Nackamichi on designing an enclosure best suited for the SP80s 8" sub (ported enclosure). It talked about the proper interior air space needed for best sound. Overall, I would highly suggest you persue these compartments for your amps. They are hidden (theft deterant) and the left space is typically not used for anything else. Also, todays market for amps offers a wide variety of sizes with specifications to meet most needs. Good Luck.
you may be able to mount on inside the rear fender, after removing the rear interior trim and speaker plate. SOmething I considered but decided wasnt worth the work involved.
I'm taking a few pictures as I go for what it's worth. I've been trying some more and the only thing that'd get the amp down in the rear compartments is taking about an inch off either side.
This morning I found the perfect place to run the amp power cable. Behind and above the battery, hidden below the bottom of the windshield there was a factory hole with rubber stopper put in that fits the amp cable nicely. No need to worry about water coming in because it's about as high up in the battery compartment as you can get. You can't see it unless you bend down and look up at the battery or take out the glove box and look from that angle.
that is a very small amplifier. I looked at that area on my car for an alarm, and decided it was unsuitable for the brainbox. I cant imagine trying an amp in there.
That is a baby amp! Thank you for the pic Jason. Maybe its worth looking for a more expensive amp that is more compact. So Jason, that amp must be setup to just add 60 watts to the output of the head unit? Can all amps be setup in this matter, or is it a special feature?
Originally Posted by Jason_86_951
Why not do it like the factory did? Behind the lower dash kick plate.
![](http://www.proctrl.com/amp.jpg)
It might be worth it to get a smaller amp. Mine is ~11 or 12 inches each side and it's barely too big to fit in the usual places - bring a tape measure when you go shopping around. Anything even a half inch smaller would've fit perfectly in the hole with the spare. I'd guess 9 or 10 inches would be about the upper limit for an amp to fit in the side cubbies and still have a little room to work with. It looks like the passenger side one filled with water a few inches deep at some point, maybe the hatch leaked awhile back. My guess is the spare tire hole is about the safest place to hide an amp if you're worried about water.
