Clunk ?
I get a clunk from somewhere in the back of the car when I change directions - forward to reverse and vice versa. It only happens once, and after the clunk everything feels solid.
Any suggestions ?
Any suggestions ?
Mine does the same and I know it is the rear brake pads moving in the caliper. Apparently a 'liner' should have been fitted last change and you can hear them move from forward to reverse and back again. I will sort it out next time round. Maybe the same for you? Adam.
Wax On, Wax Off
my tech tells me move the axle towards, then away from the transmission. if the CV's are bad, you'll hear noises.
I was gonna say there are retaining pins to hold the pads in place, but that's in NA's for sure, not too sure on the turbo.
I still think, that from his description, it is the pads. BTW, the S2 and 951 pads don't have retaining pins. The have a clip at the top of the caliper that pops out, and the pads slide out thru the top to change them. Very easy to change pads in just a couple of minutes.
